8v71 vs L10
Posted By Kobethefarmer Last Year
5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)5th Direct (803 reputation)
Posts: 680, Visits: 13.7K
I drove a truck many yrs ago with a L-10 300 HP. I thought it was a solid little engine...gave no trouble at all....good fuel mileage and the Jake was respectable as well.
Posts: 1.4K, Visits: 8.9K
A friend of mine has a L10 in one of his dump trucks and maybe 5 years ago I add about 20 psi to the rail pressure and he has no problem yet.I believe it was a 300 but he was only driver on it him self.There was two versions of this engine and I would only want the one which has the exposed dampener instead of the inclosed damperner.Some 10 engine was celect also.
5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)
Posts: 983, Visits: 3.3K
The potential torque on the L-10 sheet at over 900 lb. ft is equivelent to a 9 cylinder 71 series .............or an 8V71T or 6V92T.        6V92T should be equal , fuel and torque wise.
Posts: 1.1K, Visits: 3.8K
I had the 300hp L10 in a Pete 320 Front Loader (rubbish truck)http://forums.justoldtrucks.com/uploads/images/b39a29a5-9f2c-4824-9ed9-2898.jpg that was excellent compared to the DV550 and Cat 3208 we had previously.
Kobethefarmer
First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)First Gear (8 reputation)
Posts: 6, Visits: 36
Well, actually I am going with the L10.But I read a lot of overdrive magazines from back in the day. & The Detroit was one of the smaller but popular sized engines from that time. & I just wanted to see if a L10 could be comparable because both are about the same size.Thanks, I am not a fan of Detroit diesel, just needed to see if they could compare.
Posts: 2.8K, Visits: 18.0K
L-10 will get better milage, the Detroit will have a bit more power.  I have some seat time behind a L-10 and was impressed how well it did for its displacement.
 I guess it depends on what you want, what is important to you.
If I were looking to make a living with one or the other, I would go for the L10, If it was in a old truck that I wasn't going to work, the Detroit is more attractive.
Kobethefarmer
I am curious, how would a L10 cummins compare to a 8v71 Detroit?I know both are slow. But in terms of reliability, fuel economy,etc.
