Steering Stabilizer
Posted By TonyClemens Last Year
Posts: 1.8K, Visits: 6.7K
The basic concept of a steering stabilizer is not a bad one even if everything is sound.  Might make any truck a little more comfortable to drive.  It only effects fast disturbances, not the slow ones such as steering.
1959 Kenworth CC-925 60's tribute truck, 1980 Freightliner FLC 12064
6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)
Posts: 1.7K, Visits: 33.6K
Now I'm back in the states and can see the pictures, I do have the bottom version, with needle bearings.
I know working on my Ford pickups you have to shim the spindle for proper thrust bearing clearance.  If they get worn/loose, then I can still see this being an issue with the steering wheel shaking as the spindle bangs up/down on the pin.
Mines tapered with bushing and needle bearing upper if I recall correctly. Been 17 yrs since I did them.
Posts: 3.0K, Visits: 13.5K
That's interesting Larry. I didn't remember Mack had at least four types of king pins and bearings three of which I would call unconventional. The Type 1 is what I consider a typical king pin setup.
Type 2 I guess is what you have.
And two types of bearings on Type 3
