Engine dilema KW FRTL
tundra
Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)Fourth Gear (427 reputation)
Posts: 300, Visits: 5.1K
used ta have a few 16v71s layin round from off road end dumps back in the days I did the gold mine stuff
mosta the stuff ended up goin ta scrappers   as even the ones that didn't have ;;;ventilated;; blocks didn't have much left
did save some parts though
Posts: 2.6K, Visits: 12.2K
Needle-Nose (1/12/2019)
Freightrain (1/11/2019)
$2250 for a full dressed 8v92?   Cheap!!
Don't think anyone has posted the link of the guy on Youtube that blew up a 16v71 genset?  Everyone was crying about it.  He kept stating, come pay the $800 and take it away.  His local scrapper had a couple of them and no one wanted it.  He blows it up and everyone stomps their feet and has a fit.
Larry you see and hear that all the time, save this, save that and ragging on someone because the build or alter something to suit their vision of what they want. Unfortunately this has come to the forfront I feel due to the anonymity of the Internet. Ya wanna save it then belly up to the bar with your billfold in hand.
I've gone through this with my hot rods, but you never see them on the road with their pristine restoration. (in their words, it's to precious to take out of the garage)
5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)5th Direct (847 reputation)
Last Active: 7 days ago
Posts: 723, Visits: 14.0K
6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)
Last Active: 5 days ago
Posts: 1.9K, Visits: 34.0K
Last Active: 4 days ago
Posts: 1.0K, Visits: 3.4K
Exhaust manifolds, blower air inlet housing have been reversed and relocated with a little creativity .
WalterACRS
First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)
Posts: 22, Visits: 170
Tony Bullard (1/10/2019)
Walter did you see the Oshkosh or Walter sitting in the weeds on the north side of I90 just west of Amsterdam or Fultonville / Fonda?
No, I haven’t been that way to Fultonville in a many years.
Posts: 3.4K, Visits: 15.6K
WalterACRS
Geoff Weeks (1/10/2019)
Air compressor and Alt are ALWAYS driven off the FLywheel end on a -92, or at least all the one I've seen are.
I thought they made them both ways... if not I might have to rethink my plans... but the exhaust is a problem as well.
Posts: 3.0K, Visits: 20.3K
WalterACRS
Junkmandan (1/10/2019)
Yes, flywheels from 6 and 8V92 , also interchange with 60 series, I believe .    6V92 only uses 6 capscrews , while V8 and 60 series use 12 .
And Walter-----------Who told you those military engines ain't TA ?
I know they are 8V92TA models the problem is they have the exhaust, alternator and air compressor on the flywheel end of the engine. I need the layout to be reversed to fit into the conventional cab of a NCUS. Oh, allison’s Are the devil’s work. I am an Manual gearbox only guy.
