electronic Speedo problem
Posted By Geoff Weeks 3 Months Ago
Posts: 3.1K, Visits: 13.8K
I'm glad it all worked out. Those kind of problems can drive you crazy. I for one learned a lot about speedos.
Posts: 2.7K, Visits: 17.4K
Problem is solved. I got some miles on it now and it reads correctly. I guess you just can't get a good read with the jackshaft in place and it being so cold everything is stiff, including me!
Never doubt Glenn! Although there was no noticeable play either axially or radially and no oil leaking from the spline or the seal, when I put a torque multiplier on the nut, I was able to tighten it. A quick run up with the driveshaft down shows the speedometer reading correctly. So I looks like the problem is solved. At least I hope so.
 I decided to leave the original gear and seal in place and just tighten it, as there was no leakage and I don't like working in these cold temp. KISS!
Posts: 1.4K, Visits: 8.6K
A lot of times all you need to do is loosen up the yoke nut and retighten.I have a problem with the other truck with the tach.Its a electronic pump and the tach will jump up and down about 300 rpm if you let off or get on the gas.Only thing is this is not hurting any thing.When I ant got something to do I will. check it out
Its been too dang cold. As I said, I ordered all new and will check it out. It is about the only thing that could cause it. It is now staying about 10 mph low, which would figure if it had started to slip and has been getting gradually looser as time goes on. I'm in Montana now and the high is -5F, kinda zapp's all the motivation out of an old man to crawl under a truck!
13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)
Posts: 4.4K, Visits: 8.6K
Geoff, Just wonderin can you pull the sender out of the back cover and reach in with a screw driver and see if you can turn the luctor on the out shaft. Maybe you already have I am just wonderin.
Tony Bullard (2/5/2019)
Maybe, just maybe and I have no idea but if the rotor (12) was not sandwiched as we thought but pressed on the yoke and the bearing contacted the end of the yoke everything would still be really tight but as Glen said the rotor could be slipping.
data:image/png;base64,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
From what I remember, the lighter boxes with a smaller output shaft the gear sits on the yoke but overhangs the back end so it is pinched between the bearing and yoke, the bigger boxes with the big shaft it is sandwiched. I could be wrong, but that is how I remember it. I have both light (1100 series) and heavy (1400 and up) boxes in my stable of trucks, and have been inside on all of them,
 In both cases, the gear is a loose (slip fit) fit and it is the yoke being pulled against the rear bearing that makes the gear turn with the yoke.
I have ordered a new gear, rear bearing seal kit, and nut, Now I need the time and will to go out in the cold to drop the driveshaft and pull it down and replace.
Posts: 1.0K, Visits: 3.6K
Off topic sort of...but I had 96 Bronco was electronic but this 06 Ranger is back to mechanical , speedo that is.
Posts: 3.1K, Visits: 13.8K
Maybe, just maybe and I have no idea but if the rotor (12) was not sandwiched as we thought but pressed on the yoke and the bearing contacted the end of the yoke everything would still be really tight but as Glen said the rotor could be slipping.
