1945 REO 50V
Posted By Eddy Lucast 3 Years Ago
Posted 3 Years Ago
13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)
Posts: 4.7K, Visits: 19.2K
This a mighty old REO being reborn. It's name is Willie Make It ll, because it's headed to a show this summer, restored.
the project begins, will he make it?
The front axle's being rebuilt.
More to come
EddyLucast@hotmail.com
Posted 3 Years Ago
Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)Rocket Scientist (15.2K reputation)
Last Active: 46 minutes ago
Posts: 10.8K, Visits: 147.2K
Ken's latest project is a 1945 Reo 50V, a 12 ton 6x6 wrecker built for the U.S. Navy. Only 200 were built, and we only know of three survivors. Ken's is the only one that runs and operates. The goal is to have it ready for the MVPA show in York PA in August.
This is what it looked like prior to starting on Saturday
http://forums.justoldtrucks.com/uploads/images/17041e18-1a28-41cc-95c9-b144.jpg
http://forums.justoldtrucks.com/uploads/images/bd299dc2-1231-435e-b3a4-6eaf.jpg
http://forums.justoldtrucks.com/uploads/images/f2e86cf9-a58f-4bea-a631-adb1.jpg
By Monday it looked like this.
http://forums.justoldtrucks.com/uploads/images/8648c901-2dc9-49a0-9461-75a9.jpg
Posted 3 Years Ago
13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)13th Over (6.1K reputation)
Last Active: 10 hours ago
Posts: 4.7K, Visits: 31.8K
Is that a Waukesha gas engine, Jeff?
Posted 3 Years Ago
I just googled Reo 50V and there is a clip of it on fb-I see it has a Waukesha gas engine.
Posted 3 Years Ago
It's a 145GK Wauk Hamish.
Posted 3 Years Ago
Thanks Jeff.
Posted 3 Years Ago
Last Active: 16 hours ago
Posts: 1.2K, Visits: 4.4K
How does this Reo 50V compare with the big Sterling crane/wrecker (presumably with the same Waukesha?) for their intended work application?  Also, how would these two models compare with the big wreckers Federal 606/ White 666?  In terms of intended work application?  They were all front axle drive, heavy wrecker boom/crane.  I'm assuming different engine sizes and axle capacities, but were some more crane than boom wrecker?
Posted 3 Years Ago
Bruce, you ask an interesting question. Most of the information we have on these trucks is pieced together from several sources. The Reo 50V and the Sterling DDS235 Navy wreckers were essentially built to the same specifications. Both share the same Waukesha 145GK engine and the same transmission, transfer case, drive train, and Gar Wood US6 T26 wrecker boom. The cab and sheet metal, and the Sterling wood lined frame were the main differences. Reo literature refers to the 50V as a "10 Ton Naval Aircraft Salvage Truck", but the boom was rated at 10,000 lbs (same as the Federal C2) and the data plate stated the truck was a "12 ton 6x6 Wrecker Truck". There is no doubt the chassis is much heavier than the 7-1/2 ton Federal. The Reo chassis rails are heavily fish plated from the factory and the truck seems much more massive. The top of the engine valve cover is about 7 feet off the floor. A Reo factory image of the 50V next to a 7-1/2 ton Reo 29XS (same chassis at the Federal C2) shows the 50V to be substantially taller.
Both the Army Air Force Federal C2 and Navy Reo and Sterling had the same purpose, to recover damaged aircraft. The Air Force trucks were equipped with a 5th wheel and an underslung winch on the rear, while the Navy trucks were just a bare chassis behind the boom tower. The only drivetrain components shared by these trucks was the Timken T-77 transfer case. The Federal used the Hercules HXD engine.
There was never a wrecker built on the White 666/Corbitt 50SD6 chassis although some civilian operators added them after the war.
http://forums.justoldtrucks.com/uploads/images/36e62bff-4805-4419-8f83-92a3.jpg
http://forums.justoldtrucks.com/uploads/images/5591babd-8185-46df-91b1-94db.jpg
Posted 3 Years Ago
Ken's 50V project is moving right along with the engine, transmission and rear differentials removed from the chassis and the front hubs rebuilt by the "Hubmaster" John Gott. To facilitate cleaning and painting the frame Ken has built a rotisserie to turn the chassis to whatever angle he needs it at. Here are some photos, courtesy of Warren Richardson.
http://forums.justoldtrucks.com/uploads/images/b61cbc72-c55f-4b38-b185-f9e3.jpg
http://forums.justoldtrucks.com/uploads/images/7ecd0bbb-e1fe-4d81-a685-92f0.jpg
http://forums.justoldtrucks.com/uploads/images/b45b8462-e9a6-41a3-aa20-9a79.jpg
http://forums.justoldtrucks.com/uploads/images/9bd1ffe6-65ab-4377-a116-e488.jpg
http://forums.justoldtrucks.com/uploads/images/7b180ace-796a-4a62-a065-512a.jpg
http://forums.justoldtrucks.com/uploads/images/004da36a-c753-4db1-8804-ac70.jpg
Posted 3 Years Ago
Last Active: 2 Weeks Ago
Posts: 2.5K, Visits: 2.6K
Always nice to have some extra pieces from an Erector Set to build the rotisserie!
