Cummins turbo drain fitting
Posted By Geoff Weeks 5 Months Ago
jimfols
Posted 5 Months Ago
First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)First Gear (24 reputation)
Posts: 24, Visits: 1.0K
My pleasure
Posted 5 Months Ago
Posts: 2.8K, Visits: 18.1K
Yeah, this is for drain, but the ad doesn't have anything to gauge the size by. At little more than $10, it is worth taking a chance.
Edit:
 Ran the Cummins part number on the box and comes back as drain fitting, so that looks like it! thanks for your help!
jimfols
Posted 5 Months Ago
This could be it:
https://www.ebay.com/itm/M915-M916A1-MEP009A-NTC-290-Cummins-Turbo-Charger-Brass-Elbow-45-3000560-/201426328618
If the link doesn't work here's the item number 201426328618
It does not give the size but I have never seen a feed line like this.
Posted 5 Months Ago
That is for 5/8" tube, This is 7/8" tube, or at least fits snug into a 7/8" hose, I know an odd size. It was made by Parker, but may be special to Cummins.
Posted 5 Months Ago
It may even be 1/2" I haven't checked closely, Just going by eye.
edit: Measures right at 1" OD at ends of threads.
Posted 5 Months Ago
Posts: 3.2K, Visits: 14.2K
It might be an illusion but that looks to me like 1/2" NPT .840 OD. 3/4" NPT is 1.050 OD
Parker has a 259IFHD-10-8 45° 7/8 x 1/2 NPTM. I know you'd need a bushing but I wonder if it would pass enough oil.
Posted 5 Months Ago
Part in question.http://forums.justoldtrucks.com/uploads/images/7cceb86f-07ba-44f0-b4ea-abef.jpghttp://forums.justoldtrucks.com/uploads/images/3fa05d17-aebf-4fbd-a46d-1e57.jpg
Posted 5 Months Ago
thanks, I robbed one of another engine, but will need to replace it.
dieselsteveo
Posted 5 Months Ago
Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)Third Gear (257 reputation)
Last Active: 21 minutes ago
Posts: 196, Visits: 2.6K
If no one beats me to it, I can get you an answer in the morning
Posted 5 Months Ago
Does anyone know the part number for the 45 deg  inverted flare (7/8") x 3/4 NPT elbow used on early Big Cams, and earlyer back to the NH for the turbo drain?.
 I got nowhere on a Quick serv  search under the serial number. They seam to have no uploaded the parts for the early Big Cams.
