Air start and Brake question
Posted By Freightrain Last Month
Posted 10 days ago
6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)6th Over (2.1K reputation)
Posts: 1.8K, Visits: 33.8K
Well, all was well yesterday from pulling out of garage to backing it in again. No drag or slow release. Just normal. Guess it was the chamber? Time will tell.
Posted Last Week
Wayne, I knew there was tension from the return springs from when I had the drum off and removed S cam shaft and slack.  I didn't think that the S cam was what was the issue now.
The old chamber seems fine, but time will tell after the trip next weekend.  If it drags again?  Ugh.
Posted 2 Weeks Ago
Posts: 4.4K, Visits: 8.6K
Larry, This is why I suggested removing the chamber and using a short pipe over the slack to determine where the problem is. You have found it buddy. Go get 2 new chambers and I reckon you will be fine.
Posted Last Week
I apparently adjusted the brakes too far out, so when I pulled the pin from the slack, the slack smacked against the mounting bracket of the can.  Luckily I just had my hands out of the way.  The tension from the return springs on the brake shoes rolled the S cam back and rotated the slack.  I should have just adjusted the tension away to pull the pin, not a bunch of turns of the adjuster.
Posted Last Week
Posts: 3.1K, Visits: 13.9K
Freightrain (5/4/2019)
Put new chamber on. When I loosened brakes and pulled the pin, the slack about smacked my hand. No drag on it! Plenty of tension on shoe return springs.
Would you explain that one more time?
Thanks.
Posted 2 Weeks Ago
Put new chamber on. When I loosened brakes and pulled the pin, the slack about smacked my hand. No drag on it! Plenty of tension on shoe return springs. That ain't the problem. Hopefully the slack is.
Sadly, the can is stamped "made in China" and a big tested,designed,approved in USA sticker. Huh? Say what? The can I took off is rebuild able. This one isn't.
I'm keeping the old can and stashing it in bunk storage....just in case.
Posted 3 Weeks Ago
Posts: 2.9K, Visits: 9.4K
Put a garage door spring on the slack adjuster and hook it to the end of the truck frame and call it fixed.
Posted 2 Weeks Ago
Everything is new when I stretched it a few years back.  So it doesn't have many miles on them.  Surely no salt or brine to destroy them either.
Posted 3 Weeks Ago
Are the slack adjusters new or old, if they've gpt spme age on them they do wear internally the worm and sector aren't tight so even though the pot is in the off position the internal part of the slack may not be, and the S cam doesn't follow it thru all the way. I had one like that on he job I'm doing now.
Posted 3 Weeks Ago
Well, no leak on service side. Released brakes and it came off fully again. Ugh.
