Last Active: 6 Months Ago
Visits: 2.1K
Junkmandan (5/20/2019) Wayne Yarter did a U tube video about a year ago............It works most of the time . When you use the extension spout on the spray can, it's more effective to get the blaster in the proper places.
^^^ this. you can find me as Ol2Stroker on youtube.
Buncha junk.
Visits: 3.3K
Posts: 1.1K,
Visits: 3.8K
That PB Blaster works amazingly well...I've tried all the old standbys over the years but I think PB is the best.
H.S.Blake 1971 IH VCO(T)-190 Leach 2R Packmaster Fawnskin, CA 6,750 feet above tidewater
Posts: 1.8K,
Visits: 8.7K
OK I will give that a shot. I watched a video on YouTube of a guy doing about the same thing.
1959 Kenworth CC-925 60's tribute truck, 1980 Freightliner FLC 12064
Posts: 3.2K,
Visits: 14.6K
I just freed some up on a 6V53. Removed both fuel lines and squirted carburetor or brake parts cleaner through either of the injector ports 'till it came out the other. Worked the plunger up and down as I ran the rack in and out. Freed up almost immediately. Sprayed some PB Blaster through it and worked it again. Smooth as silk. Now if I could only sell the engine.
Posts: 1.8K,
Visits: 8.7K
I have 2 injectors where the racks are sticky or stuck to where they don't move easily. Is there a way to free them up? I am not a detroit guy. The intent is to see if this engine will run and is sound before we prep it and tune it for swap into the FLC.
