Air conditioning
Posted By Aaron Last Year
Posts: 2.9K, Visits: 19.4K
Rob may be right, never occurred to me to think along those lines, as it is the wrong place and the wrong device. I will add if you go with a Tx valve you will need a frost switch in the evaporator. One reason I didn't recognize is they normally go in the outlet of the evaporator.
 In refrigeration there were "quick connect": fitting so the parts could be shipped charged, and assembled on site that looked something like that fitting.
Posts: 3.1K, Visits: 10.0K
Thanks guys,
Rob I was kinda wondering along those same lines but not so much as  a do it your self type thing, I kept thinking it was  a factory setup as this pickup has not been fouled up in any way I guessing it still had the orginal plug wires on it, its an xlt ranger and nothing is out of place on it except the hood, half the paint is Arizona burnt off the seats and carpet have virtually no wear.
  But after a few more ph calls yesterday it turns out those are disconnect valves, there are replacements out there, Old Air Products knew what they were and had a set but there is another bunch of o rings to give fits with so just deleting the little center plugs I'll put the bodys back in service as they are needed to connect to the dryer.
Rob
5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)5th Direct (858 reputation)
Posts: 396, Visits: 5.1K
Just seeing this. Someone in a prior ownership either had some HVAC experience, or worked with someone that did and tried some adapting. What you have there is a mechanical suction throttling valve attempting to replace the original POA valve, (pressure operated absolute) on the outlet of the evaporator core. POA valves were commonplace in automotive HVAC systems for many years and being mechanical in nature were a high failure item, (usually jammed open). The "orifice tube" systems replaced this in automotive use. POA valves controlled evaporator pressure and refrigerant flow by monitoring outlet pressure in the evaporator core. The throttling valve does the same on the inlet side using a set of springs to set the calibration of the unit. They are unfit for use in a system where the refrigerant compressor changes speeds. These are routinely used in commercial type refrigeration units and the Carrier corporation calls their variant an "Accurater". They are used on the inlet side of the evaporator core and never before a filter/dryer assembly as your installation is.
There is a company in Florida that manufactures a replacement sleeve for the POA valve, and an adapter to retrofit an expansion tube into the inlet line of the evaporator and it works well. You could incorporate an adjustable expansion device into the system and set your superheat at about seven degrees and subcooling to best attained valve, but that's a bit above this conversation.
What you have there is neither factory, or conventional aftermarket supplied but rather someone's attempt to "rig" something up. It would work fine if the engine were set at a constant speed however, but a very narrow window would exist for this application. I'll try to remember to look in the files for the vendor in Florida but it's been many years ago since I've last purchased from them.
Happy New Year to everybody!
Rob
Disseminator of intimate knowledge of nothing about everything.
6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)6th Over (2.2K reputation)
Posts: 1.9K, Visits: 34.0K
It can be random anymore. He used to be Johnny on the spot. Now it can take days. I have my times where I'm not on there for extended times, like any of my popular spots.
I've looked at LMC, nothing, any of the books I've got nothing, my older parts supply houses, nothing,although I've got to wait for NOS to open later in the week.
 Larry I've got a disc going on over there and made  a post for Bill to check into it but haven't heard from him, I haven't been on there in about a month is he still on it.
W921
First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)First Gear (47 reputation)
Last Active: 4 days ago
Posts: 40, Visits: 137
Are you sure its OEM? Ive never looked at LMC website. I just call them and they mail me their catalogues. Every vehicle I own is at least 40 years old and their catalogues have always been dead on.
Interesting.  Like some kind of check valve?   My '67 had underdash unit installed(dealer?) but don't recall anything like that.  I looked through a few older books I have and found nothing.
Bill(NumberDummy) over on FTE is a retired parts guys and pretty handy on stuff like this.  I knew another fellow Jeff(Jeffafa) that retired and also left the site this past summer.
Yeah been on the ford enthusists board, had quite a bit of help from a gent there, need to contact one more.
John R. Thomas
First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)First Gear (26 reputation)
Posts: 20, Visits: 158
Have you emailed to the Ford truck forum?
factory set up, no salvage yards around close by, dryer coming in today
Got a couple napa kits nothing fits and what was on the little valves had com apart the screen at the compressor was full of crap,gonna flush the system too.
