K 100 questions
Posted By Gascat 5 Months Ago
braketester
Posted 3 Months Ago
Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)Third Gear (201 reputation)
Posts: 185, Visits: 3.4K
Yes definitely a disc brake . Could be old style Rockwell or Eaton. Eaton was messing with a air disc setup in the late 70s. Hard to tell what the manufacturer would be .If you can get a lower pic that would help to identify.
Brian
Brian M. Bittner
Stoystown, PA.
Posted 4 Months Ago
Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)Rocket Scientist (12.7K reputation)
Posts: 9.0K, Visits: 142.6K
This makes my neck feel better.
http://forums.justoldtrucks.com/uploads/images/31bbc681-a7bc-49fb-aba8-855e.jpg
Posted 4 Months Ago
Posts: 4.0K, Visits: 16.4K
I talked to Charlie Hatfield a couple weeks ago. He's working on his 34 Mack fire truck that came with disk brakes from the factory. I questioned him if they were original. He says Doug verified it was originally built with them.
Chopped Liver, I've got my own rope thank you very much.
Gascat
Posted 4 Months Ago
First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)First Gear (15 reputation)
Posts: 9, Visits: 627
http://forums.justoldtrucks.com/uploads/images/044f6dbd-c143-4ce8-ad36-17c.jpeg
Gascat
Posted 4 Months Ago
http://forums.justoldtrucks.com/uploads/images/1a0492a4-65d0-4de9-b079-313.jpeg
Posted 4 Months Ago
Posts: 3.0K, Visits: 20.3K
Rick Knox (3/6/2020)
PIE was running disk brakes by the left 60s
What did they run on the right?:P
Rick Knox
Posted 4 Months Ago
6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)6th Direct (1.7K reputation)
Posts: 1.3K, Visits: 5.6K
ATHS Executive Secretary
ATHS Life Member
Rolling along in my LIL Green White 3000
Grain Valley Mo.
Posted 4 Months Ago
Posts: 1.0K, Visits: 3.4K
Cleveland Fire Dept had some disc brakes in service in early to mid 90s. When I first heard about it a 2 axle pumper was in for a "poor parking brake" problem . Rotor was gone on right rear wheel .
Regarding Brian's comment, local customer had Louisville Ford tandem with rear drum brakes and hydraulic disc on steer axle .in the '90s .
GearheadGrrrl
Posted 5 Months Ago
Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)Second Gear (115 reputation)
Last Active: 4 Months Ago
Posts: 100, Visits: 1.1K
Probably was a PIE tractor- They spec'd disk brakes for a while back in the 70s.
braketester
Posted 5 Months Ago
There were discs on fire trucks.Rockwell had discs back then . I wonder if they were air over hydraulic . I have seen those type of brakes.
Brian M. Bittner
Stoystown, PA.
