Starting an NH 220
Posted By TonyClemens Last Year
TonyClemens
5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)5th Direct (977 reputation)
Posts: 682, Visits: 10.2K
Thanks, Tony, this diagram is what I need.
Posts: 3.6K, Visits: 16.8K
Download this one http://photos.justoldtrucks.com/default.aspx?moid=26929
and get a little creative. I'm not trying to be sarcastic. Between the two you should, may be able to figure it out.
TonyClemens
Tony, that worked but it shows the 24 volt system with the SP switch. I'm wanting to change it to a 12 volt starter and eliminate the SP switch.
Tony go back and select "original" and then download next to it.
TonyClemens
Tony, I can barely see it for some reason but I believe that's what I need. Here's my email   twclemens@hughes.net
I just fixed the Photos and Documents Library. You can down the full size now.
Somehow that file is a resized resolution image. Tony if that's what you were looking for send me your email address and I'll send you the full version. I can't add attachments through the JOT email.
From  http://photos.justoldtrucks.com/default.aspx?moid=26930
More from http://photos.justoldtrucks.com/default.aspx?aid=811
TonyClemens
Pulled the old SP switch and it basically fell apart. New one is about $160. Don't know about the starter's condition, could be bad. I've been advised to change out the starter and just switch over to 12 volt. Anyone have a wiring diagram?
Posts: 3.2K, Visits: 22.6K
Here is new, but rebuilt would be cheaper
https://smithcoelectric.com/products/240-821-new-alternator-for-delco-30si-12v-90a-with-24v-transformer?_pos=515&_sid=2f492f8df&_ss=r
 or any 30SI alternator can be converted with just the TR section added on the back
https://smithcoelectric.com/products/500-12113n-new-transformer-for-delco-30si-12v-to-24v-5a?_pos=1111&_sid=2f492f8df&_ss=r
