1946 Federal Fire Engine
Posted By ADV TRIO Last Year
Stretch
Posts: 1.0K, Visits: 6.4K
Get a few volumes of "Motors" manuals near the vintage of your truck. Good general information.
Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)Rocket Scientist (13.5K reputation)
Posts: 9.6K, Visits: 144.2K
All of the small 1940's Federals like this one I have seen have had a Hercules under the hood.
Bud Tierney
First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)First Gear (41 reputation)
Posts: 38, Visits: 149
Federal was one of the last "assembled" trucks, so all the mechanical parts will be off-the-shelf components from various well known suppliers, so parts should be no problem, your engine almost certainly Continental ot Wauk...if a Wauk the Wauk Eng Hist Soc will have manuals (no parts) and help/advice...
(every time i say "parts no problem"t about a postwar 1940s truck I.have to remind myself  that while it was almost new  eqpmt when i started driving, a LOT of tims's passed)...
As suggested, repost in the main forum; if no old firemen chime in, and you have questions about the fire  eqpmt, also post on one or more of the firetruck forums too, and you'll find many kindred souls...
Stretch
Now I get it.
Posts: 3.6K, Visits: 16.8K
 "In the fall I drained the water out of the system and used compressed air to get every last drop out of the system to keep it from freezing.
In the spring I closed all of the drains and petcocks and connected the garden hose to the pump to pressurize it at 60 psi. "
I think what he meant here was draining and charging, priming the fire pump.
Stretch
The truck probably doesn't get a lot of use, so maintenance is less of an issue than freezing as has been mentioned.
The enemy of old trucks is lack of use. Causing dead batteries, leaking seals, corrosion, etc.
Start it often, take it out  and drive it a bit. (Don't forget to put coolant in it if it has been drained. Make sure you tag it out of service when the radiator is drained
so you don't forget and overheat it.)
13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)
Posts: 1.7K, Visits: 2.0K
You must be in northern CA with the snow on the ground!
*Always think for yourself. Don't trust the government.
Posts: 3.8K, Visits: 17.0K
Post this picture and your questions up in the Peter J's section. There are several very knowledgeable Federal men here.. Be sure to look it over good for the data plates.. They should tell you what engine it has in it.
13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)13th Over (5.9K reputation)
Posts: 4.3K, Visits: 17.6K
If you are not sure of what you have take pictures and post them, a lot can be determined from those, the more the better.
John R. Thomas
First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)First Gear (30 reputation)
Posts: 24, Visits: 188
The person in charge of maintaining it should be a gear head.  Open the hood.  The engine should be easy to identify.  The oil filter should be visible and marked.
Did the service records come with the rig?  Basic maintenance should be easy.  I owned a 55 Peter Pirsch for 10 years.  It was powered by a Waukesha 145GKB
gas 6 cylinder engine.  In the fall I drained the water out of the system and used compressed air to get every last drop out of the system to keep it from freezing.
In the spring I closed all of the drains and petcocks and connected the garden hose to the pump to pressurize it at 60 psi.  Good luck.
