Bodybuilder drawings
Posted By Geoff Weeks Last Year
Posts: 3.2K, Visits: 22.6K
Yeah the brackets are the same, but the spacing is NOT. It was a Hendrickson design, Not Marmon, Marmon Group own Triangle spring, may be that is what you are thinking.
 The front 4 spring bracket is the same used in front of the front and rear axle on an air ride, the center bracket on the 4 spring, is the same raw casting but is machined to accept the "equalizer" (rocker).
 I have one IHC on air and one on 4 spring. The torque arms are different on rear axle than the front with 4 spring, both the same on the air suspension. The rear arm is longer on the 4 spring.
Last Active: 15 hours ago
Posts: 4.7K, Visits: 9.1K
The front and rear brackets are the same pattern as the front bracket on the IH 4 spring. I know because I converted a 9670 from IH 4 spring to IH Z leaf. By the way the IH Z leaf as designed by Marmon.
13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)13th direct (3.4K reputation)
Posts: 1.7K, Visits: 2.0K
OK  Got the same results.  Found a bunch of IH suspension drawings but no luck for the Z.
*Always think for yourself. Don't trust the government.
To be clear, I am looking for something like this except for the Z spring suspension
Thanks, I've seen those, what I am looking for are the lay-out drawing showing bolt spacing and bracket dimensions for the fame layout.
 I am transposing a IHC suspension that is in pieces onto a truck that never had that suspension on it.
 I have a cabover that has the same suspension, but rather than 'reverse engineer" it over to the other truck I was hoping to find the drawings like I did for IROS suspension.
Z Beam?  May help.
http://www.truckcomponentsonline.com/Corporate-Air-Suspension--Rear-SingleTandem-Axle--Z-Beam_c_706.html
Does anyone know where I can lay my eyes on bodybuilder drawing for the IHC Z spring suspension? I have found them on line for the newer IROS suspension, but I need the Z spring.
