Cummins flywheel
Posted By 1wonton 2 Years Ago
1wonton
Posted 2 Years Ago
First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)First Gear (11 reputation)
Posts: 10, Visits: 57
The teeth on my Cummins HI are stripped; where can I find a new/used flywheel?  What flywheels are interchangeable?
ron
dieselsteveo
Posted 2 Years Ago
Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)Third Gear (380 reputation)
Posts: 292, Visits: 3.8K
There were a handful of different flywheel options and ring gear options for the HI. If you can share your engine serial # I can try to find the parts your engine was built with and try to find options for you.
1wonton
Posted 2 Years Ago
Thanks Stevo;  where would I find the engine #?
1wonton
Posted 2 Years Ago
Found the engine #; HI 37297
Posted 2 Years Ago
Posts: 1.0K, Visits: 3.5K
You don't need to replace the flywheel for a bad ring gear.   Ring gears are an industry standard........more or less !     Plus should be a part # on the ring gear for your search . Pop it off, measure ID and count teeth . Shouldn't be anything out of the ordinary .
1wonton
Posted 2 Years Ago
Number on flywheel H20024 and on the ring gear H5711.  Where can I find this ring gear?
dieselsteveo
Posted 2 Years Ago
It appears Cummins still sells the 5711 ring gear!!  I see it in our parts system, can call tomorrow to find out price and stock.
Alternatively:
http://srsales.com/ has 25 of the 5711 ring gears in stock.  You will need to create a free account, check inventory for 5711, add one of those to a quote, and submit it for pricing.  Once you get their email quote, if you are ok with the price you can call them to provide payment and shipping info.
Arkansas Valley Diesel Service also has one on their eBay store for a eye-popping $392
A Google search for "cummins 5711 ring gear" generated a few other sources...
1wonton
Posted 2 Years Ago
Thanks Steveo;  I checked the cummins site and didn't find this number, if you have a price or other location I'd sure appreciate it.  I also signed in to the srsales site, will wait to be confirmed.  Can you tell the year of this engine?
ron
dieselsteveo
Posted 2 Years Ago
Your engine was built late August 1943.
I called about the Cummins stock. There are 5 of the ring gears in Singapore :) But...$361 + $36 in shipping.
1wonton
Posted 2 Years Ago
Thank you for the information.  I called Cummins and the 5711 gear is similar but instead of 1 inch wide it is .871.  Sacramento Clutch and Brake has them at $120.  I'll check and see if my Bendix will work..
ron
