Garrison Control Valve
Posted By Stretch 6 Months Ago
Posted 6 Months Ago
Posts: 3.5K, Visits: 11.2K
They are not o ring boss on the top of the cylinder, just regular 1/2" pipe.
I've done the ones I put together with a solid shaft just because, mine had a slight bend in it when I got it and when i put the garrison I added the rod.
Stretch
Posted 6 Months Ago
Posts: 1.1K, Visits: 6.7K
Hi Tony,
My control valve has 90 degree fittings screwed into the body. The end that was leaking looked like JIC. Maybe the other side of the fitting is O-ring boss, but
it's dry now.
Posted 6 Months Ago
Posts: 3.7K, Visits: 17.8K
Stretch (5/12/2021)
Got the tie rod off. It's bent in multiple directions, including the stem of the tie rod end where it screws into the rod.
Going to borrow a straight rod from a donor chassis.
Control valve leak seems like it was just a loose fitting.
I believe those are SAE O-ring Boss fittings. They use SAE O-ring Boss o-rings. Not just a regular o-ring size.
Stretch
Posted 6 Months Ago
Aaron,
Do you think the rod needs reinforcing to handle the force imposed by the steering cylinder ?
I was thinking the damage was related to `the truck ending up in a ditch. The underside of the passenger side fuel take was stoved in also.
Posted 6 Months Ago
I'd put a solid shaft in it also.
Stretch
Posted 6 Months Ago
Stretch
Posted 6 Months Ago
Thanks again Aaron.
It's nice to have an idea of what's in there.
Posted 6 Months Ago
Straighten in a press, get a solid shaft that fits inside, bore  a few holes in the tube and plug weld it, been running mine that way for years.
You don't have this?
I'll put all of what I have up, Tony would you be able to move them to the other section.
http://forums.justoldtrucks.com/uploads/images/0f6235cb-dff6-41b6-8183-31bd.jpg
http://forums.justoldtrucks.com/uploads/images/b0bf780b-799c-4025-b65c-3157.jpg
Stretch
Posted 6 Months Ago
Thanks for the reply Aaron.
Sounds like we have different 8 page sections of the manual. Mine has no breakdown of the control valve .
Installation instructions. See attached.
The tie rod in question also has a nice bend in it where it was driven upward (truck is an ex-logger). How do you feel about straightening in a press ?
Garrison Installation.pdf (11 views, 2.00 MB)
Posted 6 Months Ago
All of the above Jim, LaChance told me to turn the ends of the tie rod but i never have, seems to me to be counter productive of what the tie rod is made to do.
 Thats all I have is that 8 page book, it has the complete breakdown of the reaction rings and how its put together, I have one that needs the same thing but the rings in mine need to be changed to a little slower set of rings as I'm always sawing on the wheel to keep it in line, the one on the truck now works correct, I'll most like;u send it to SL: for an overhaul.
