AC 1824 Fuel Pump
Posted By jhancock 2 Months Ago
Posts: 2.4K, Visits: 2.5K
Thanks for the info and assistance!
mark h
First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)First Gear (39 reputation)
Posts: 38, Visits: 78
From an Aug. '51 AC fuel pump book #A-683 found online. Page #10 Add prefix 152 to number stamped on carb. 1521824 crosses to replacement carb # 557. #557 0n page #12 carb repair kit with rocker arm, kit # RA-56. Fuel diaphragm # D-38. Page #8 Truck & Tractor applications : 1939-41 Mack with Continental engine. No other listings.
mark h
Posts: 3.6K, Visits: 11.6K
Call Jon at the carb shop in Missouri, he does carbs but may have the pump books
(573) 392-7378
General Posted 2 Months Ago
Anyone happen to have an old AC fuel pump book?
Wondering what the application for an 1824 might be.  Probably late 30's vintage or so.  It has a staggered mounting bolt pattern.  It can't be assembled straight on, it is either kinked to the right or left.
Not a critical situation just curious.
