Wheel history
Posted By TomC750 2 Months Ago
Posts: 3.6K, Visits: 11.6K
Mine was egg shaped and twisted.
13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)13th Over (6.3K reputation)
Last Active: 24 minutes ago
Posts: 4.6K, Visits: 19.0K
Aaron has a guy who's straightens them.
EddyLucast@hotmail.com
TomC750
Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)Fourth Gear (408 reputation)
Last Active: Today @ 1:24:17 AM
Posts: 342, Visits: 1.9K
Tony Bullard (6/24/2022)
Geoff Weeks (6/24/2022)
It seam like it is likely an RH type. Both the RH and the RH 5 deg wheels suffer from a very narrow cross section where the rim and ring lock together.  It is easy to deform the side ring taking it off, and can cause failure.
You're right about deforming and its almost impossible to repair them correctly.
Here's a 16" split ring that was deformed into a helix causing the diameter to change also.
My solid ring was not deformed at all. But it did bother me a bit that it was lighter and smaller in cross section than the others. The wheel was slightly different as well, mainly, the groove the ring engages in is deeper, that is, wider across the width of the rim.
Tom
I was eventually able to straighten it with clamps, shims and bar clamps to correct the diameter.
TomC750
Bill Bradford (6/23/2022)
Tom, I have a WWII Gmc . this is from the manual. Sorry for the bad copy.
http://forums.justoldtrucks.com/uploads/images/f925e8b8-4abe-44d6-ae82-27c8.jpg
Bill, I use a heavy rubber hammer with shot to install rings. Works really well and avoids touching up paint.
Tom
5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)5th Over (1.5K reputation)
Last Active: Today @ 12:06:48 AM
Posts: 1.3K, Visits: 4.8K
What I find interesting is you could have Budd disc with Firestone or Goodyear type rim, and vise-versa.
Thats whats on my truck.
Last Active: Today @ 1:59:36 AM
Posts: 3.5K, Visits: 28.2K
ring pried out without pushing the bead back! With a spit ring, where the bead goes over the ring when the tube/tire is inflated, it is imposable for it to come out, It is only when the bead DOESN"T go over the ring and push it into the groover tighter that they come apart. The solid rim/ solid ring types don't have the beard over the ring, but butt up against it.
 With the split ring types once the bead is over the ring, you could cut it into segments and it still would not come apart.
I was referring to the solid side ring/solid rim Firestone type.
Posts: 3.8K, Visits: 18.9K
13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)13th direct (4.6K reputation)
Posts: 4.2K, Visits: 19.8K
TomC750 (6/23/2022)
Brocky (6/23/2022)
My 49 Diamond T on Eaton axles, Dayton wheels, has those solid rings also?
Hmmm, I'm surprised!
And a guy at Macungie had a little earlier Studebaker 1 ton with the same axles and rims.
Bill Bradford
5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)5th Over (1.1K reputation)
Last Active: 59 minutes ago
Posts: 734, Visits: 26.1K
