Visits: 2.4K
Awesome thank you all, I will try and take it apart today, we didn’t get a chance today as we were focused on the Pacific. I might be able to get down tomorrow to grab some dimensions and see what is happening inside the cylinder…
Scott McKenzie ProGraph Solutions Ltd. - Mechanical design and drafting
Posts: 3.9K,
Visits: 19.7K
Here are the old Wagner part numbers.  For wheel cylinder cups Raybostos used the same digits with a WCC prefix, Wheel Cylinder Cups.
Posts: 3.9K,
Visits: 19.7K
ScottM (11/18/2022) Awesome okay, I will take it apart this weekend and see what it looks like inside. Once dimensions are obtained for the components inside where would I find a replacement cup?
It would be easier if you give the dimensions and than I can give you the part number to look for. Wagner and Raybestos.
Visits: 15.8K
ScottM (11/18/2022) Awesome okay, I will take it apart this weekend and see what it looks like inside. Once dimensions are obtained for the components inside where would I find a replacement cup?Knowing where you are just take the parts or dimensions to your Lordco dealer and they can probably supply or know where in Prince you can get em.
Posts: 2.6K,
Visits: 2.7K
Depending on how bad it is inside, a call to a bore and a stainless sleeve company may help with a resolution. As an example. https://whitepost.com/brake-sleeving-rebuilding-services/
All brands of turbochargers professionally rewound and synchronized. ------------------------ No one ever said "My garage is just too big". ---------------------- Just because you're offended, doesn't mean you are right.
Visits: 2.4K
Posts: 3.9K,
Visits: 19.7K
Anyway you cut it I think your idea of cleaning it up and honing it and getting new cups and pistons by size is the best way to go.
Posts: 3.6K,
Visits: 29.6K
Anyway you cut it, it is Wagner. Can't find my Wagner books.
Posts: 3.9K,
Visits: 19.7K
I think the FC is the aluminum reservoir. The cylinder is cast iron with a F, FD or FE number.  I don't see anything in the old Wagner Illustrated Reference Guide that looks like this.
Posts: 3.6K,
Visits: 29.6K
The FC number is a Wagner number but nothing "pops" on the internet. If it were I, I would take apart and clean it, may be hone the bore, sometimes you get lucky and that is all they need.
