Wecleom Guest
Login
Register
Home
Search
Tags
Calendar
Members
Whos On
Photos
Classified Ads
Latest
Popular
Home
Old Snow Plow Equipment
Old Snow Plow Equipment Resources
Technical Info (Kind Of)
Starter Motor Performance Curves
Posted By
8 Years Ago
Post Reply
View
Flat Ascending
Flat Descending
Threaded
Options
Subscribe to topic
Print This Topic
Goto Topics Forum
Posted 8 Years Ago
Visits: 255
Do you see how similar these graphs look? All series wound dc motors no matter the horsepower or voltage have the same characteristics. There is much that is perhaps counterintuitive here and information about starter motors that will not come easy. Did you know that starter manufacturers actually specify available cold cranking amps (cca) that you should NOT exceed?! If you look at these curves and think about it you start to understand what is going on electrically (and thermally.) Where is the most power developed? At approximately 2/3 the nominal voltage, around 9 volts for 12 volt systems and 16 for 24 volt systems. In our battery ratings we find that those cca ratings also have a voltage factor, that is the cranking amperes have to be at a USABLE voltage, or about 7 volts in a 12 volt battery. The current goes off the chart as the voltage drops and the rpm lowers until the starter stalls and we have what is called locked rotor current. For all real world practical purposes it is as close to a dead short as we can get without being a dead short...if that makes any sense? When cranking voltage in a 12v system falls below 7 to 9 volts we should start troubleshooting. The batteries could be failing, there could be mechanical problems with the engine causing increased drag, starter problems, bad connections, cold weather and thick oil or? Starter too small for the job? Will have to continue this later, need sleep.....
performance curve
starter motor
Reply
Quote
Post Reply
Share
Subscribe
RSS
Back To Top
Explore
Home
Latest
Popular
Tags
Search
Forums
Forums
PeterJ's Place
Thoughts and Wishes
What Am I?
Members Trucks
Mechanical Questions and Answers
Vendors and Restoration Services
Photo Gallery and Document Library
Photos (Redirect Forum)
Documents (Redirect Forum)
Trucks
FWD Trucks
Linn Tractor
Oshkosh Plow Trucks
Walter 100% Traction
Lombard Loghaulers and Tractors
Sterling Trucks
Marmon Herrington / Howe Coleman 4WD Conversion Trucks
Mack Snow Fighters
Sicard Plow Trucks
Plow Equipment
Snow Plow Manufacturers
Tracked Plows
Power Angle V Plow
Snow Rollers
Truck Collections
Mr. Oshkosh's Oshkosh Memorabilia
Harrisburg International Airport
Town of Springfield Trucks
Leo Frank's Truck Collection
Bernard Powers 1957 Chevrolet Plow Truck
Vintage Salvage Yards
Miscellaneous & Off Topic
Slightly Off Topic
Miscellaneous
Show Plow Stories
Bad Day Plowing
Classified Ads
Visit our Classified Ad site
Jump To Page
Jump To Page
