ChipAustin Battery Replacement
Posted By bshoesey 10 Years Ago
Posted 10 Years Ago
Last Active: 8 Years Ago
ChipAustin`s Walter Battery RelocationThis is a featured page
inside of the cab, stock Walter battery location between the seats
Inside the cab, stock Walter Battery location, makes it hard to use a battery charger or remove the batteries
Pull rope threaded through frame
pull rope threaded through frame
series parallel switch
Series Parallel Switch
Back end of pull rope by rear wheels
Back end of pull rope near rear wheels
new 2/O battery cables cut to length
New battery cables cut to length.
battery cable end assortment
preparing cables for new ends
Preparing cables for new ends
crimper
Crimper
new end crimped on
new end cripmed on
I didn't trust just the crimp, so I crimped and soddered the eyelet ends that go on the series parallel switch
end soddered and crimped
finished cables for the switch end
shrink tubing
shrink tubing
adding shrink tubing and battery terminal ends
finished length
finished length
cleaning up the ends for shrink tubing
Adding shrink tubing
Adding shrink Tubing
Positive side
Positive side
new ends labeled for correct positions
new ends tied to the pull rope to go back through the truck frame to the parallel switch
new cables back at the front of the truck thanks to our handy pull rope
new cables hooked to parallel switch
new loction of batteries on the catwalk area behind the wing box
new location of batteries on the catwalk area behind the wing box
close up
close up
new cables through the frame
scrap plywood turned in to battery cover
battery cover assembled
in place
in place
