Battery Cutoff Switch
Posted By oldtrucknut74 7 Years Ago
Jess
Posted 6 Years Ago
First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)First Gear (91 reputation)
Posts: 43, Visits: 253
I have one on just about all are equipment and like the ones I get at cat the best they are made by cole herst and have never had any trouble with one I always put it on the ground side that way when installing batteries if you touch the pos post and frame with a wrench it will not do anything if switch is off. If installed on pos side battery pos post to ground will always spark no matter switch position
Posts: 1.2K, Visits: 4.1K
You should probably get a 2 pole version, I got the C-H 75907 (2000amp intermittent) one, and route the alternator field feed through it, if you throw the cutoff if the key switch is on, it could kill the alt. diodes. I found that out the hard way years ago.
Just a thought.
Posts: 3.0K, Visits: 20.3K
Ground is only ground if it connected to one side of the battery, if the ground side is open (not connected to the battery) then there is no short.
Mark Brubaker
Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)Fourth Gear (484 reputation)
Last Active: 3 Months Ago
Posts: 322, Visits: 1.9K
I'm an electrical dummy. I never understood why the switches are installed in the ground side of the circuit. If the truck develops a short and the positive is not disconnected, then won't the juice find it's own ground and make the switch useless?
'74 IH 4300
'78 IH 4070B
"Politicians are like diapers they need to be changed often, and for the same reason." -Mark Twain
Posts: 4.0K, Visits: 16.4K
Peter put two of the Cole Hersee switches on the Mack. One for the truck batteries and one for the battery pack that feeds the camper.
Chopped Liver, I've got my own rope thank you very much.
Posts: 1.3K, Visits: 1.7K
I have used a couple of different brands and have installed them on the ground side.
*Always think for yourself. Don't trust the government.
J Hall
First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)First Gear (16 reputation)
Posts: 13, Visits: 36
John Deere industrial dealers stock a pretty good switch, $37.00 Or you could go to Caterpillar for one with a key. The Cat switch will handle anything. I have a loader with a 3412 engine with two starters and four group 8D batteries going through one master switch.
Last Active: 5 days ago
Posts: 4.6K, Visits: 8.8K
John, me too. Wayne
John Woge
Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)Fourth Gear (416 reputation)
Posts: 250, Visits: 3.6K
I use a Cole Hersee(sp?) on the ground side of each pair of batteries. Can't remember the #, but it's been heavy enough so far
john
oldtrucknut74
Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)
Group: Anonymous / Guest
Last Active: 5 Years Ago
Posts: 216, Visits: 562
Any suggestions or recommendations for brands of cut off switches to use on 12V system on a big truck? I've been through two of them on my truck in the last few years. It took me awhile to figure out how long to crank the engine when it won't start. I had the IH dealer install one when I first bought the truck and they installed in on the positive terminal. Does it matter if it is positive or negative connected? Pros and Cons for either? I just watched a video on the Flaming Rivers Brand and have also found a cutoff switch that is used for heavy equipment on Amazon.
Thomas Hudgins
1970 Chevrolet K20
1974 International F4270 Eagle
