Air horns
Posted By oldtrucknut74 7 Years Ago
Posts: 1.2K, Visits: 4.3K
I have the OEM IH horns (with the logos) made by Grover. Parts are still available as far as I know.
oldtrucknut74
Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)Fourth Gear (441 reputation)
Group: Anonymous / Guest
Posts: 216, Visits: 562
Tony Bullard (10/8/2014)
A picture is worth a thousand words.
My guess is there's no fix to the die cast pot metal diaphragm retainer. Is it a Bendix? I have parts for some of those.
Grover has some nice horns. http://airhorns.com/products.aspx?category=truck
Tony,
My truck is out of my yard for about a week due to having some mechanical work on it. When it comes back, I'll take a picture. Original horns with IH logo. Not sure of the manufacturer.
Thomas Hudgins
1970 Chevrolet K20
1974 International F4270 Eagle
Posts: 3.4K, Visits: 10.8K
The Grover horns don't have air on the cap side where the screws are,the air is on the horn side of the diaphram,there is a gasket between the mounting pedestal and the screw down head,also they need to be tuned.
Last Active: 26 minutes ago
oldtrucknut74
Problem Posted 7 Years Ago
Any one ever restore old air horns? I took mine apart this summer and cleaned them. I put them back together and there are a few cracks in the rear screw plates. I started up my truck yesterday after finishing some ceiling work and the air horns sound worse than they did before I cleaned them out. I can hear air leaking out of the cracks. What would I use to seal the cracks? Silicone? Would finding new plates help or maybe replacing the air horns in general. I found some air horns made by Wolo that look like they might fit with the mounting style that my truck has on the roof. I would rather fix them if I can instead of replacing.
Thomas Hudgins
1970 Chevrolet K20
