1979 Peterbilt 352
Posted By easy money 4 Years Ago
easy money
Posted 4 Years Ago
Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)
Posts: 78, Visits: 236
Just bought this old truck. Looking forward to fixing it up!
roKWiz
Posted 4 Years Ago
5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)5th Direct (786 reputation)
Posts: 604, Visits: 11.6K
Good to see another Cabover. You guys certainly have long wheelbases compared to Oz.
Cabover Nut
In order that the labour of centuries past may not be in vain during the centuries to come...Denis Diderot 1752
Posted 4 Years Ago
13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)13th Over (5.1K reputation)
Posts: 3.6K, Visits: 14.4K
roKWiz (6/1/2015)
When the over all truck lenght was restricterd to 55 feet, the longer tractors seemed to ride better, when the over all lenght laws were relaxed a trucks wheelbase turned into a kind of contest, braggin rights if you will. You're likely to find some extreme examples!
http://kbs.justoldtrucks.com/
easy money
Posted 4 Years Ago
I like a little longer frame than most trucks have from factory, but this one seems to be perfect for me. I dont like the extremely long frames I see sometimes. Definitely looking forward to getting her fixed up and out on the road.
Posted 4 Years Ago
Last Active: 10 hours ago
Posts: 1.8K, Visits: 8.6K
Sharp 352.  What are the other specs?
1959 Kenworth CC-925 60's tribute truck, 1980 Freightliner FLC 12064
easy money
Posted 4 Years Ago
I was told that its a 290 BC Cummins with only 600 miles on rebuild , 15spd  over, Eaton 3:55 rears, air ride suspension AND cab as well. It has new brake drums, chambers, shoes, new goodyear virgin tires, driveshafts, and it has factory a/c but is not operable right now. Also has air/power passenger window. Its very solid mechanically it appears. But the interior is just worn out really bad and smelly. I plan to start stripping out the carpet and panels soon. The mechanic at our shop says if it is a 290 it has had the stuff added to it. I assume for more power and things of that nature. I really haven't done anything to it or went very investigating the engine to verify what has been added to it. He kinda looked it over when we got it back to the yard.
