What Am I for Wednesday 10/03/12
Posted By Jeff Lakaszcyck 9 Years Ago
Posted 9 Years Ago
Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)Rocket Scientist (13.7K reputation)
Posts: 9.7K, Visits: 144.6K
Interesting bottom dump. Photo from John Algood.
http://forums.justoldtrucks.com/Uploads/Images/2b6cff54-f287-438c-a160-3b9c.jpg
What Am I 1967.jpg (11 views, 131.00 KB)
ppsyclone
Posted 9 Years Ago
Posts: 1.1K, Visits: 10.8K
White, about 34-35
Bill White
Posted 9 Years Ago
13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)13th Over (8.6K reputation)
Posts: 6.0K, Visits: 9.1K
White
1953 White WC24, 1949 IH KBS11
Posted 9 Years Ago
Posts: 3.8K, Visits: 17.2K
Will go along with the White. A municipal one set up for a snow plow with the high mounted headlights.
Jack Amaral
Posted 9 Years Ago
Posts: 1.4K, Visits: 9.2K
WHITE
autocarjim
Posted 9 Years Ago
Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)Third Gear (309 reputation)
Posts: 299, Visits: 4.4K
White
dclerici
Posted 9 Years Ago
Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)Second Gear (133 reputation)
Posts: 116, Visits: 934
Well I'll say Mack (just to buck the trend) and I'll guess a Cook Bros. trailer (later in life would have been Challenge-Cook).
Posted 9 Years Ago
Posts: 1.1K, Visits: 4.0K
White, 1934 first version of styled cab before the Safronosky cab later in 1934. That cab survived though in special models in the late 30s. Short hood would be a 718, but I didn't think they'd have air brakes.
chocko
Posted 9 Years Ago
Last Active: 4 days ago
Posts: 1.3K, Visits: 3.8K
Bruce if not air brakes they could have been vacumn brakes. Joe D.
Posted 9 Years Ago
Majority rules, this is indeed a White. Bruce says it is a Model 718 and that sounds good to me. The 700 series Whites were introduced in late 1933 and continued in this style through 1935 until the famous Alexis de Sakhnoffsky styled models were introduced. White did continue to use this cab on some low production models, most notably the 4 ton Model 950 military 6x6's built in '39'-40. Our WAI truck has the construction style fenders seen more often on later models. It is pulling an AW spreader. Brian Kelly had this 1st by a minute. Thanks to John Algood for the WAI pic. The only other photos I have of Whites with the construction fenders are later models, as is this one from Don MacKenzie. The ad for a 1934 Model 712 is from my collection.
http://forums.justoldtrucks.com/Uploads/Images/7e57152d-25c2-45fe-9a4f-f1ef.JPG
http://forums.justoldtrucks.com/Uploads/Images/e8da650d-2885-4e7e-9706-b2f6.jpg
http://forums.justoldtrucks.com/Uploads/Images/ee9fe92d-500d-4d50-a093-f39e.jpg
