Posts: 3.8K,
Visits: 18.6K
I believe you have to register there. You can use the same login info as here. Most of us do.
Visits: 8
When I try to sign in it says my information is incorrect. Shouldn't my log in be the same as here??
Posts: 4.6K,
Visits: 18.8K
Ads get posted here http://buy.justoldtrucks.com which will allow you to post free ads. The bonus is they get picked up by the search engines quickly.
Double Mountain Manufacturing LLC EddyLucast@hotmail.com 203-228-1961
Posts: 4.6K,
Visits: 18.8K
Visits: 8
I have finally gotten to the point were I can remove the engine and transmission out of my 1947 Federal 25M. I am going to re-engine with a modern Cummins and I really would like to find a home for the motor and transmission instead of taking it to the scrap yard. Motor has 31,000 miles on it. It won't turn over but all I have attempted was putting some break free down the spark plug holes. Since I do not plan on using it I haven't put more effort than that in to it. The motor had good anti-freeze in it when I removed the radiator I found this out the hard way. I'd like to get around $450 for the combo but I would be willing to negotiate. I
