Posts: 3.8K,
Visits: 18.6K
I think they first started using the PCV valves in WW11 on tanks for going under water while fording a river. The crankcase was plumbed to the air cleaner which was ported to a snorkel above water.
Posts: 3.5K,
Visits: 27.8K
Those PCV valves were common on many engines. They are "take a part" for cleaning and didn't need to be replaced. Dunk them in a carb clean tank and you were good to go until the next "tune up".
Posts: 10.6K,
Visits: 146.9K
The old 4 cylinder Jeeps had that same PVC check valve,, years before they were mandated by Uncle Sam.
Tony, I hope to have the C2 here by next week sometime.
Visits: 8.1K
It must be a Hercules thing, my '47 Federal w/a JXB has the same sort of check valve off the tappet cover, and a 'cute' little oil bath cleaner off the oil fill tube.
xxxxxxxxxxxxxxxxx PROGRESS WAS ALRIGHT ONCE, BUT IT HAS GONE ON TOO LONG
Posts: 3.8K,
Visits: 18.6K
Stretch (7/7/2016) Is that an oil bath crankcase breather ? Looks to me like that engine was a runner before it was layed up.I think you are kinda right Stretch. But it must be a coalescing filter to separate water and oil vapor vented from the crankcase. The water and oil must settle to the bottom and have to be dumped when full.  |
