replacement door handles for Pete 352
Posted By easy money 5 Years Ago
Trenton
Posted 5 Years Ago
First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)First Gear (70 reputation)
Posts: 38, Visits: 472
Very happy to read that they will work out for you.
Trenton
easy money
Posted 5 Years Ago
Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)Second Gear (109 reputation)
Posts: 78, Visits: 236
Man I can't thank you enough. I believe they are exactly what I need. I ordered them so we will see soon enough. Thank again for the help!
Trenton
Posted 5 Years Ago
Good afternoon easy money,
I stumbled across this eBay auction and thought I would pass it along to you. I have no connection to the auction. I found it after looking for door handles to a kenworth sleeper. The eBay auction number is 141996077614 .
I hope it is of some value to you.
Trenton
easy money
Posted 5 Years Ago
Finally got time to measure the handles. The mounting bolt holes are 1.5" center to center. The square part of the shaft is 1.75", but it could vary slightly and not cause any issues I believe. I didn't get the bolt size yet.
easy money
Posted 5 Years Ago
no problem.....Im not concerned with them being identical factory replacements. Just trying to make a nice working truck.
Posted 5 Years Ago
Posts: 3.4K, Visits: 10.8K
The spd way's won't quite work,the handle it self isn't long enough to twist,I believe they will screw on but the shaft may be too short.
 I think Phal in PA may have them on his web site, They would be for earlier cabs, they are not 100% like the Petes but fairly close,they would be what I would look at if I needed any,just don't tell anyone they are Mack.
easy money
Posted 5 Years Ago
I will get the measurements this afternoon and post them.
Posted 5 Years Ago
The Speedway shaft is 1-7/8" long. What is your mounting screw size and center distance and how long of a shaft do you need?
easy money
Posted 5 Years Ago
I havent yet, but I think that shaft you mentioned will be too short.
Posted 5 Years Ago
Did you check these specs?
Specs
Sold in Quantity:
Pair
Finish:
Chrome
Material Type:
Zinc
Overall Width: 4.00
Mounted Length: 2.13
Base Width: 2.00
Base Height: 1.13
Note: Uses a 5/16" square shank which has a 3/8" long turned down O.D. of 1/4" which is 1/8" from the end of the shank.
