Last Active: Yesterday
Posts: 3.2K,
Visits: 22.6K
C&H in South Sioux City, NE might be a good place to start. The 17220 should be fairly common as it was used in a lot trucks. The other one might be a bit harder to find. I used a 17220 to replace the rear rear in a DT402 set. Just changed the side gears. There are 4 or so on Ebay right now, you would have to check the casting number to determine the series, but it is a good bet at least one or 2 would be a 17220
Last Active: 2 Years Ago
Visits: 2
I am looking for RS17220 and RS23240 two speed differentials. Does anyone know where I might be able to locate them? Thank you.
