1950 (?) Oshkosh W-514-D
Posted By WrenchR 2 Years Ago
WrenchR
Posted 2 Years Ago
First Gear
First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)First Gear (25 reputation)
Posts: 20, Visits: 135
WrenchR
Posted 2 Years Ago
First Gear
WrenchR
Posted 2 Years Ago
First Gear
Brocky
Posted 2 Years Ago
13th direct
13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)13th direct (4.4K reputation)
Last Active: 1 hour ago
Posts: 4.1K, Visits: 18.6K
NO Plow equipment or controls??? Any idea of it's prior career??
Brocky
WrenchR
Posted 2 Years Ago
First Gear
Brocky, when I initially discovered the truck it had a sander on the rear but no plow or plow mount. I had no use for the sander (which was in poor condition anyway), so it was discarded. It looks like there are some mounting holes in the frame between the front spring hangers and bumper that could have held a plow mount at one time, but I’m not familiar enough with these mounts to know for sure.
WrenchR
Posted 2 Years Ago
First Gear
Stretch
Posted 2 Years Ago
5th Over
5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)5th Over (1.3K reputation)
Last Active: 9 hours ago
Posts: 1.1K, Visits: 6.8K
Sounds Great!
And Thirsty !
WrenchR
Posted 2 Years Ago
First Gear
Per Mr. Oshkosh, this truck was built in May, 1958 and sold to what would be come the FAA in Anchorage, Alaska. And here’s a nerdy detail - this truck was delivered to the Territory of Alaska, as we didn’t achieve statehood until January of 1959.
Also, here’s a little more background on why the truck was retired - transfer case issues. When I acquired the rig it’s transfer case had been dismantled and left outdoors for years and is not salvageable. I’ve found another at a wrecking yard in Nebraska that will begin it’s slow journey here (truck-barge-plane) next week or so.
jhancock
Posted 2 Years Ago
13th direct
13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)13th direct (3.9K reputation)
Last Active: 10 hours ago
Posts: 2.2K, Visits: 2.4K
WrenchR (10/1/2020)
(truck-barge-plane)
Hmmm.... sounds like a chance to make a new version of the film "Planes, Trains and Automobiles"
      All brands of turbochargers professionally rewound and synchronized.
               This is sketchy even by my standards...   Uncle Tony
           Just because you're offended, doesn't mean you are right.
WrenchR
Posted 2 Years Ago
First Gear
The new (to me) transfer case is on it's way! Photos taken (by C&H Truck Parts in Nebraska) after removal from the donor truck show a nice and clean auxiliary section. Hopefully I can get this thing moving under it's own power before the snow arrives!http://forums.justoldtrucks.com/uploads/images/4f799c24-d016-40b2-bd71-027d.jpghttp://forums.justoldtrucks.com/uploads/images/90730869-f55d-4f18-8f23-2045.jpghttp://forums.justoldtrucks.com/uploads/images/406d9a0b-cbb4-4c52-bc24-fdb0.jpg
